I’ve owned this 2005 Stingray with a 4.3L Alpha 1 for three years. It’s always had a mild vibration that never went away.
Recently, the gimbal bearing started making noise. I pulled the outdrive (it was tight coming off), replaced the bearing, and checked alignment. The alignment tool was tough to insert and remove.
I adjusted vertical alignment and got it close. Using a 1” wooden dowel in the coupler, I saw possible horizontal misalignment too. I haven’t tried loosening the motor mounts from the stringers and shifting the engine side to side yet — I’m not sure how much play there is.
After rotating the crank 180°, vertical alignment was suddenly off again. I cut the dowel shorter and ran the engine with it in place — visible wobble (video coming).
So now I’m wondering if I’ve got two separate issues:
Kids are one me to get the boat in the water.
Any feedback is greatly appreciated and honestly, a few words of sympathy at this point wouldn’t hurt either.
Bill in Southern, NH.
P.s the 1” dowel is straight/no warp
- This wobble confirms a bad coupler correct?
- How much horizontal adjustment is possible at the mounts, and could both issues be related?
