help determining replacement hub
findinghomer
I have a 2001 ez loader trailer with failing bearings. I want to order replacement hub kits rather than replacing the bearings and race. http://www.iboats.com/Trailer-Hub-K...+Engineering&gclid=CJCAobbG6r4CFQGPOgodZ1kAwA This hub kit fits all my measurements, lug pattern, bearing size, and weight rating. But it does not look the same as the one on my trailer. So my question is , will this Work? Or do I need to take something else into consideration? Or do I need ez loader oem parts? Any feed back will be greatly appreciated!
bruceb58
Honorary Supreme Mariner
You need to know your axle dimensions or at least the inner and outer bearing numbers of your current hub.
findinghomer
when you say bearing numbers, do you mean the bearing size? Bc I do know that, I replaced one set of bearings already
four winns 214
My 1999 E-Z Loader has some funky hubs made by Unique Functional Products, but I think the spindles will take "normal hubs". The only sure way to find out what hub will fit your spindles is to carefully measure them with an accurate micrometer.
