'93 150 Johnson 150 GLETR
Had this boat for about a month now and everything has been pretty solid. Been out 4 times with only one issue. When I first had it out it stalled at WOT. At WOT, boat would stall, surge, stall, surge before finally coming to rest. No alarms. Pumped some old gas out, replaced gas, replaced fuel filter and all was well until this weekend. That happened only once and I've had it out three times since no problem.
This weekend cruising at near full throttle and did the same stall, surge, stall, finally die. This time it didn't start back up right away but finally did after 20-30 minutes of sitting and trying to crank it. I did pump the gas tank out a couple of weeks before as mentioned above but I'm guessing there was still some 1-2 year old gas from previous owner at the bottom of tank. I've ran probably 30 gallons through it. Finally got it started and it ran fine.
The next day I was at idle and twice got a steady alarm. Immediately shut down, fished for a bit, and it started right back up. Steady alarm should indicate overheat or fuel flow restriction. Engine didn't feel hot and I could touch the block. Again, we were just idling around.
What should I start to look at?
