raven1978
Thread starter- Joined
- May 19, 2009
- 99
Hey guys, once again im looking for insight into this. A couple weeks ago i had a prob with carbs flooding, so i did a carb rebuild, and set floats level. Now it seems to idle & troll much better, BUT i now have a different problem with what seems like having no fuel in the carbs when i go to launch. For towing i tilt the motor up and lock it in place then when i get to the launch i set it in the water and tilt down enuff to get the water intakes wet. Press bulb till firm, turn key, press in to choke for a 5 or 6 count then turn it over. At this point i have to go back and press the bulb again till it gets firm yet again(this is why i believe i have a no fuel prob in the carbs). After repeating this process for, i dunno 3 or 4 times it will eventually start. I have done compression test (148 in each cyl), i have good spark, but the one thing i do NOT have is a venting gas cap. Not sure if this makes a whole huge difference or not with this current problem. Its getting rather embarrassing when i go to the launch and it takes me like 5 - 7 minutes to get my motor running & there's usually 10 people at this boat launch. Once it has ran/ been run i usually have no probs the rest of the day, it's only after it has been removed from the water and sat. I am wondering if there is supposed to be a check valve between the portable gas tank and the fuel pump? Or maybe that's what the bulbs purpose is, to act as a one way valve. Would replacing the primer bulb fix this long starting process? I am fairly new to the boating community so please forgive if this is a dumb a** question. Any and all help is greatly appreciated and you guys rock.
BTW motor is an E50tlccs Evinrude 50 hp VRO disconnected
peAce and FISH ON.
peAce and FISH ON.
