BTMCB
Thread starter- Joined
- Sep 15, 2009
- 761
Hey guys and gals,
After a quick trip to the lake last night, after retrieval as I was removing the plug I noticed that one of the screws (three in total) that hold the brass plug insert / flange / thingamagig to the transom was missing (see photo). When I got home I thought I would simply replace the screw with some 5200 around it. However, while I can't be certain it appears that the screw did NOT back out but instead it broke apart and just the "head" a few threads are missing. In other words, I could not insert a new screw - it hit something and wouldn't go in. I remove the plug after each trip and reinsert before the next, so this just must have happened. Couple questions: (1) what should I do (2) until I do what I should do, should I be worried about water intrusion? The fitting / flange / thingamagig is not loose, appears to be fully seated and no water came out of the bilge when I took the plug out last night.
Thanks in advance for any help, comments.
Brian
Brian
