Help Drive Oil Leak
Tod
hey guys, new guy here. i need a little help with some repair. my drive oil is leaking out of my 96 celebrity bow rider. i made a really lame diagram but it might help. there is a small hole on both sides of the foot and oil is leaking out of one. all over my garage floor! im fairly mechanical and im wondering is this an easy fix? any info will be really appreciated.
Tod
Re: Help Drive Oil Leak
Is this and easy fix? i have never worked on boats before. more of a car/ bike guy. should i just tear into it and pull the foot apart or what? i have never seen the inside so idk whats in there. i feel like it cant be to difficult but im looking for opinions. anything i should look for after i get in there? looks like 5 bolts gets the bottom of the foot off and then what. any advice would b great cause im probably gonna tear it apart 2morro. thanks in advance.:D
dubs283
what is the make/model of drive you have????
refer to the sticky at the top of the forum threads, get as much info as possible then post yer question
Tod
K, I took the foot off tonight and i think i have solved the oil leak. pretty simple inside, but i have a question. right behing the drive shaft was a hose approx. one inch in diameter. i dont see how i could make absolute sure that it connected. while putting the foot back on i tried to make sure it lined up and slid in place. my question is, before i take it to the lake - what is that hose for and what if it is not connected properly? what is the worst case scenario? i think it is on there because the hose was pretty stiff and seemed like it would have no choice but to slide on. is there any way to make sure it did connect propery? thanks in advance for any advice.
Tod
bump. please any help would be great. im gonna take my boat out tomorrow but i am just wanting to know about that hose behind the drive shaft. what is it for? and what if it is not connected properly. will i be doing major damage? how can i check to make sure it is connected? any suggestions please. :confused:
please any help
Ayuh,.... You've gotta Help yourself before any of Us can help you Dude,....
You've been asked very Important Questions(see post #5),...
Without Answers,....
There's No Help available.........
Tod
well let me try to better explain. mercruise sterndrive. alpha. 4.3 liter. basically i pulled off the lower drive assembly and found the drive oil leak. i think that problem is resolved. my question is when i put the lower drive back onto the upper assembly, there is a hose coming from the upper assembly approx. 1" in diameter. it is located directly behind the drive shaft. it connects to the lower drive assembly. how do i know it connected properly? seems like the only way to put back together was to lift lower assembly back on and hoped the hose lined up. seems shady to me. sorry dude i am a boat rookie. any help?
Ayuh,... just Sayin',... That shoulda been the very 1st thing you stated,....
Not all boats are the same man...
In the Adults Only section are links to All kinds of this info, with Pictures,.. Manuals...
There's several things that must be perfectly aligned to reinstall the lower unit...
That water pipe is but 1 of them.....
Tod
tks. i just looked at the service manual. i think i am good to go. so this is the water intake tube i am assuming to cool the motor. i still dont really see how (while assembling) to be sure it aligned properly but i ran the boat at the house - hooked to the hose. it goes in and out of gear fine. i assume if i were to take the coolant hose off in the engine compartment where the water would be entering the engine, and water is coming through - then everything should be good. is that a safe assumtion?? the rest seemed pretty cake. i dont see what else could really be wrong. any thoughts??
