HELP***Dropped gas can nozzle into gas tank
mmitchellnc
I know it sounds dumb, but the gas can nozzle snapped off and fell into my gas tank. Any ideas on how to get it out? Or, do I need to worry about it? Could it cause problems for me in the future?
KRS62
Re: HELP***Dropped gas can nozzle into gas tank
Is the part plastic? Is your fuel tank permanently mounted? I am not an expert, but I would try to get it out if you can.
KRS
mmitchellnc
It is plastic. The fuel tank can come out with a little work. Problem is that it's full of gas at the moment.
j_martin
I wouldn't worry about it. The ones that get you are the little foil seals from oil bottles, they can cover the pickup screen. :eek:
sschefer
It' highly likely that the only future problem you'll have is pouring gas from the container that it broke off of.
Chris1956
Honorary Supreme Mariner
It is not a important issue. The next time you feel like it, remove the fuel gauge sender unit and fish it out of the tank, thru that hole.
