IES99
Thread starter- Joined
- Jun 3, 2008
- 271
I need some electrical lighting help: anchor light will not light. The light itself is good: I jump wired it from my Jeep battery to check. The fuse is also good. The problem is low voltage (checked with voltmeter at wire to the light) I only get about 2 volts. Shouldn't I get 12+? Is it the switch? or something else I need to look into? In Advance: Thanks
