Help! Electrically challenged..
jsboo72
I have a CS 17' that I bought a while back and recently powered. Now I am at the wiring part of my project. I want to install the bow and stern lights and I also have a bilge pump and live well I want to power. So, my question is....how do I do this? I have a fuse box/panel and I have 4 switches. Not sure which switch to use for what or how to wire them. . . I know for some folks this is probably a simple task...I must have A.D.D or something when it comes to wiring because it becomes really confusing for me. Any help will be appreciated.
jsboo72
Re: Help! Electrically challenged..
Still confused....
Ayuh,... There are 2 pinned info threads, Right above this post that cover your questions...
Have a Look...
Silvertip
Honorary Supreme Mariner
To help you a bit, think of electricity like water flowing through a pipe. It has a source (a bucket, a well, a water tower, etc), flows through a pipe to a house where it branches out to other things like front of house faucet, back of house faucet, kitchen taps, bathroom taps, etc. To turn the flow on and off you need valves. Electrical switches are akin to the faucets in a water system. So -- electricity flows from the soure which is the fuse panel for your purposes, but the actual source of power is the battery. From the fuse panel, current flows through a fuse to whatever switch you want to control whatever device you have in mind. Swiches are ON/OFF devices and function very simply like cutting the wire. OFF = open circuit hence no current can flow. ON = closed circuit so current can flow to the device. At the device current flows through the bulb (a light) and back to the battery via the ground wire. You NEVER put a switch in a ground wire. Here is a diagram of a complete circuit -- which in this case is a simple light.
The only switch that differs from this is wiring for the Nav/Anc lights. These are wired with two different types of switches. For your purposes I suggest this one. It is a simple ON-OFF-ON switch. Both the switch and diode are available at Radio Shack.
