incrediblened
Thread starter- Joined
- Apr 24, 2009
- 148
I am finally getting everything back together on my 470 power steering upgrade. I didn't expect this problem... but my engine coupler doesn't align with the gimbal bearing. It appears that the engine is sitting on the inner transom plate too low.
Are the fiber washer & spring whatchamacalit the only things between the engine mounts on transom plate and the flywheel cover. It appears that the engine needs to sit 1/8 to 1/4" higher.
Help... soooo close, but yet so far away.
I can't even get the engine alignment tool INTO the coupler. It's that far off.
