help engine stalls
dondi
1985 16 ft thundercraft 140 merc I O
rebuilt carb, rebuilt fuel pump, new coil, ignition,new plugs, replaced fuel lines cleaned fuel tank, replaced fuel seperator.
took her out today she ran great for 15 minutes. came back to dock, it started running rough, then stalled, would not start?what else could it be help!!
dingdongs
Re: help engine stalls
check where you have 12v.maybe you fitted the wrong coil and did you replace points and condenser.a cheap multi-meter on the boat is a godsend and keep it on there.
Fishermark
Check for spark first, simply because that is easy. If you have spark, then it is time to check your fuel. But one thing at a time. ;) Check for spark and tell us what you find.
dondi
ok ,thanks for your help. this is the best place ask advice, lots of good knoledge
