Help finding correct service manual?
akincer
I have a 2006 Sea Ray 185 with a Mercruiser 4.3. The engine serial number is DW626893. It is the carbed 190HP version. I would like to purchase a service manual, but I'm not exactly sure what I'm looking for. Is there a part number or version number specifically for this engine/outdrive or do I just go by the year? Also, do you have suggestions on the best place to purchase a manual. Thanks for your help!
Fun Times
Re: Help finding correct service manual?
Hi there, Your serial number is 0W626893. One of the service manual part numbers you need is 90-861328 1, 'AKA' S.M #25 located here, http://www.maxumownersclub.com/forum/site_files/manuals/mercruiser/25.pdf
Also depending on how far your going in to repairs, you may also need service manual part number 90-864260020, Supplement #37 Mercruiser dry-joint exhaust system & 90-866202, Turn Key Start Supplement #41 (TKS) Both found in BT Doc's link or Google search the part numbers to buy.
akincer
Excellent - thanks so much for your help!
