MickLovin
Master Chief Petty Officer
Thread starter- Joined
- Feb 18, 2013
- 822
Re: Help Frank
- 100HP Chrysler carburettor change from wb24B to TC5D
Can I rejet the TC5D carbie down? it did seem to use a bit more fuel but not too bad, if I did what size, I had .080 on the wb's and not sure on the tc5d's. Also these carbs seem to leak a bit mainly after choking, but I have noticed fuel in the motor compartment below the carbs, they are clean and don't leak from the seals. Is it normal to have leakage or should I put a complete kit through?
