Re: Help,gas in oil tank
Welcome to Iboats waterboy.
You should be fine, but please go ahead and tell us the make and model of your PWC.
YES. Siphon the gasoline out of the oil tank and replace with the manufactures recommended oil. You may want to add some oil to your gas (100:1 or 50:1) and run it easy until you can verify that your oil pump is working. You may also want to do this with a little bit of gas in the tank so that you do not have to be stuck with the gas once the problem is solved.
I am assuming you have not ran the PWC with the gas in the oil tank. Right?
