jeffdjpeat
- Joined
- Mar 25, 2009
- 125
My 1991 Merc 60hp is giving me a head ache. i bought the engine a week ago, and cannot get a tell tale flow. I have changed the impeller, cleaned the housing for the impeller, pumped water from the tell tale back through the motor and that worked fine, then i pumped a hose from the bottom end line up through the motor, and that was clear. I put her all back together, and started it up, i have water spitting out the 2 exhaust ports below the tell tale, but only steam, and the odd droplet from the tell tale itself. i am running it in a large bucket since i dont trust the muffs on larger motors. where did i go wrong?? the motor is a 91 merc 3 cylinder, 2 stroke. made in canada, serial number A717699. Also when i installed the new impellor it seemed like it was too big for the housing, took me 30minutes to force it in. did they sell me the wrong impeller? are the fins supposed to be curved a lot when in the houseing? this is my 2nd new impellor, the first one i think i installed wrong and it torn 2 fins off, but i did the water flush after that happened.
Any help Please, i wanted to try the boat out this weekend, doesnt sound like im going to get a chance!!
