Help!!! help!!! Right battery for Yamaha 50 ??
nippnsc
I have a yamaha 50 4-stroke on a pontoon boat. I need a new battery, and I am hopelessly confused. Starting battery vs. deep cycle vs hybrid??? regular acid vs. AGM???
I need a good starting battery, and the only accessory is a radio, and, rarely, running lights.
BUT--sometimes I do not use the boat for a week or two, so I need a battery that is likely to work well after that inactivity.
I don't care about cost--I want whatever will best serve my needs.
thanks!!!
JimS123
Re: Help!!! help!!! Right battery for Yamaha 50 ??
DC / Starting combination AGM. So much better than the rest that you'll never be disapointed as long as you take care of it. I currently have 5 - the oldest is 12 years.
Any moment someone will come on and say buy a wally $19 special and throw it out every year.
boobie
Look at the cost of all these batteries and then decide what you want and how much service you expect out of them.
nippnsc
But I need to know what TYPE of battery would best suit my needs. I am not worried about the cost--I have been stuck with a dead battery too many times.
JimS123
I listed the best type in post #2. When light usage is involved a dual purpose is the only way to go. A strong but straight starting battery won't like to be discharged and recharged a lot. An AGM has a slow rate of discharge anyway.
To go even 1 step better, buy a group 27 when your owner's manual probably specifies a group 24.
Regardless, if you buy a $2.99 multimeter from Harbor Freight and check your voltage before you ever go out, you'll never have a dead battery again.
matt167
Multimeters are free this month with a purchase and coupon
BaileysBoat
This comes from Yamaha-
Other Battery Thoughts
The final word on what type/size/rating of battery you must use is in your outboard?s owner?s manual ? for example, Yamaha Marine Group specifies flooded-cell batteries to avert potential overcharging gel-cell or AGM during extend periods of high-speed engine operation.
I use a good wet cell combo battery from NAPA
boobie
Bailey, I think you answered it all and I agree.
roscoe
If you sit at anchor with the stereo (regular stereo with a couple small speakers) running for long periods of time, then get a dual purpose wet lead acid battery.
If you run the motor while using your electronics, then a wet lead acid starting battery is more than adequate.
Just about any battery out there should give you the cranking amps you need.
Look for a battery with at least a 500 cca, or 650 mca rating.
A series 27 is a bit larger than a series 24, and would give you more reserve capacity, but a series 24 is definitely enough for your use.
You should be able to get one for 80-$100, that should last for 5-10 years if taken care of.
*** But, if you have a large stereo with amps, and use it while the motor is off, then you need to install a separate deep cycle battery for the stereo.
