First off excuse my nasty looking transom. I'm going to clean it up and paint it one of these days.
What do you guys think?
I used a transom off an old inflatable boat as the riser. It's 1" thick and it has the metal bracket in the front and a 1/4" piece of wood in the back to spread out the stress of the outboard.
1978 Evinrude 25 hp but I have a carb from a 35 i'm going to put on it so it will be a 35hp motor (in theory).
It rises 7 1/2" above the transom. There is only 7" below the top of the transom. Is that enough??
I have four 3/8" X 4" long bolts holding it in. I don't care for how I have em spaced but I had to put them near the edge since the riser will be removed and a prop outboard put in its place (didn't want the bolt heads in the way of the clamp screws). Do I need a bolt or two in the middle?
Is the wood thick enough?
Does the jet look like its high enough or to low or about right? It hangs about 1/4" under the boat.
I want to make a run on the river tomorrow but i'm kinda nervous about this (tower of power).
