Help identifying, came with boat, hoping its a marker.
Bustedknuckle84
Is this a marker or can be used as one? If so how do you use it to mark a structure?
oldjeep
Re: Help identifying, came with boat, hoping its a marker.
ANchor light?
Fisherball
Make sure the line will spin off it freely, drop it in the water. The weight will pull the line down & the buoy will float so you can find your spot again. I've seen them used for marking structure for fishing but it would work for a chest full of gold too.
Bustedknuckle84
so this will work to mark a spot??
pmillar
No, no, no, no. I thought everyone knew that X marks the spot.
ac0j
If the line on it is longer than the depth of water you throw it in! It could be used a s a marker, I dont think that is its intended use. I like the "h" shaped markers They will not spool off more line than needed to hit the bottom, and they have a larger weight on them. This keeps the marker above your hot spot.
