Help Identifying Cooling Hose Part Number
Horigan
I want to replace the U-shaped cooling hose in the image below (#17) that's between the fuel reservoir and the power steering cooler on my OMC 5.0 EFI motor (see signature for part number). Unfortunately, the parts number given for #17 is for a different hose (oil cooler to gimbal). The ID of the hose is about 1". Can anybody help me identify a replacement part number? I assume there's a Volvo equivalent given this is a joint venture motor/drive.
Thanks in advance.
Horigan
Found it after scanning multiple Volvo diagrams. One thing I've learned is that carbureted engines have the power steering cooler upstream of the raw water pump, whereas EFI engines have the power steering cooler, and fuel reservoir (cooler), downstream of the raw water pump. The initial part number I was getting was for carbureted models.
