Help identifying the water coming from inboard/outboard motor on right side of wake
macmike79
Took the the boat out last night and beach it to swim on the lake. Engine was tilted up but wondering if a passing boat wake pushed the lower unit into ground. After leaving I noticed this spray coming from the wake. Any idea what is causing this. 2015 Bayliner 215 deck boat. 4.3 mercruiser inboard/outboard
  • IMG_2547.mov
macmike79
Can someone please help me identify what is causing the water spray from outside right wake
  • IMG_2547.mov
Fun Times
Do you happen to have an overall photo of the aft end of the boat while on the trailer? And one of up under the swim deck?
04fxdwgi25
Transducer for your sonar / fishfiner or what ever is on the transom?
04fxdwgi25
Should probably close your 1st thread concerning this.
It is something hanging below the hull that is mounted to the transom. Probably a transducer. Very common and some of them have add on (read cost extra) splash guards available. Normally caused because the xducer isn't mounted correctly / too deep or angled wrong.
