Help identifying this broken part? pic attached
TheBlitz
I have a 1993 135 Blackmax. I am having a new issue which I believe I have finally narrowed down. I can run the boat idle and in gear as long as I am going slow. Once I try to accelerate to get to plane the motor feels like it has lost 75% of its power. Tonight I pulled the spark plugs and ran a few simple compression test and it seems fine.
Once I looked under the flywheel I could see a loose magnet that was hanging down about an inch. I believe it has swung around and knocked a tiny control arm off the stator which is attached to a lever. I am just wondering what the little lever does and if this is my problem. Also to replace that broken part will I need a new flywheel and stator?
Dukedog
broken piece is trigger (controls timin').. replace.. stator probably beat up and flywheel probably also junk with broken magnet.. need ta replace those also...
TheBlitz
Thanks Dukedog. I will definitely be replacing all of those items. I think this may be a dumb question but I am assuming the symptoms I was experiencing is due to the broken trigger? When you say it controls timin I assume when I call for more power from the engine that trigger allows more power to be generated to the motor?
