can i measure the bore of the carb throats to determine which carbs they should be 115, 140 etcThe 90, 115, and 140 all used different Carbs. While on the outside, they may have looked almost the Same, rest assured they were not. Jetting, Air Bleeds and other differences in Fuel Delivery Circuits, as well as Venturi and Throat Sizes. Also, putting Carbs from a 115 or a 140 on a 90 only resulted in a 90 with the Wrong Carbs. same went for the pre 85 115, 140 carbs didn't turn it into a 140
