I'm looking for some help in choosing a new prop for my boat. I am not having a real performance problem but would like to improve the performance of the boat overall.
I have read a lot of stories of people switching to a four bladed prop and having performance improve both out of the hole and on the top end. But I have also read horror stories of a four bladed prop killing performance all together, I am really wanting to put a four bladed prop on but don't want to regret it.
Here are the specifics on the boat/motor:
1. I would like to get a bit more speed out of the boat. I consistently see 33 MPH on my GPS. I think there is a little more in this boat than that. It does ok out of the hole but it certainly doesn't leap up on plane like a ski boat. It does get the job done though. I can squeeze another mile per hour or two out of it if I trim it way up but then get into a porpoising situation which is no fun at all.
2. Currently the boat sports the factory Evinrude aluminum 3 bladed prop.
3. Diameter and pitch is 13 1/4" X 17"
4. RPM at WOT is unknown. The boat does not have a tach so I can't say. I can verify that the throttle butterflies are all going wide open though.
5. The engine is a 1981 Evinrude 3 cylinder 70 HP two stroke, the model number is E70ELCIM.
6. The boat is a 1983 Starcraft 17' aluminum bass boat. Weight is unknown.
I have a feeling that just replacing the factory prop with an exact replacement would probably improve the performance of the boat quite a bit. While there are no chunks missing from any of the blades there are a couple of obvious dings. One of the blades is fairly bent and I am sure it is hurting the performance quite a bit. I think it is just a case of a 30 year old prop showing its age.
So what do you experts say? Should I go with a 3 blade or 4 blade? What diameter and pitch on each?
Thank you all very much for any help you can provide.
