HELP** in the middle of working on the boat, need and answer. PLEASE!
beason
I am working on my boat 2005 chap with Volvo Penta GXi 5.0L engine.
I am replacing the circ pump, the impeller, idler pulley, and thermostat.
Is the impeller housing supposed to spin separate from the crank pulley? see this pic.
i seem to remember spinning it before to get better angle on the screws that hold the two halves together, and it make sense that it would stay still while the crank and spline spin, but its not spinning. Maybe the bearing seized. if so, how do i get the housing off the spline?
Thanks in advance!!!
beason
two for one!!
how do i get the thermostat out of this? is it even supposed to be up in there??
magarmuch
Yes the impeller housing needs to spin on the shaft.
The thermostat is wedged into the housing by an "O" ring. Clean the housing and you will see the O ring. Pry out the O ring and the thermostat will come out.
PatinIdaho
Is that what the "O" Ring is for?!!
Mine is held in with a big PITA Snap Ring!
beason
yea, the bearings in the pump are shot. I took the pulley off so i can order a new one.
lots of scraping and the thermostat is replaced.
thanks to all who replied.
beason
looks like im going to order the rebuild kit. i got the bearing freed up, so i thing i can get it apart to replace it, and the seal.
beason
all done! the rust was a pain, but it got it all apart, cleaned up, and put back together. All that is left is installing the raw water pump on the boat, and doing a test run.
