jjay74
Thread starter- Joined
- Jul 8, 2007
- 46
with the help of Roscoe and others, my motor has been identified as a 1989 Force 85 HP. Purchased the FK1204 water pump kit with housing and replaced it last week. Couldn't get the motor to pump water on the muffs, so used a barrell and it worked like a charm.
Took her to the river yesterday and it was REALLY pumping water...both out of the exhaust holes and the pee hole add on. Had some surging and hesitation in the motor, so I bought some seafoam to put in the tank.
Put the seafoam in tonight, put the foot in the drum and cranked the motor. Water was coming out of all the right places. Walked away for about 45 seconds while it was idling and when I came back, I noticed that the hose had fallen out of the drum...but the water was still above the level of the inlets on the foot, so I put the hose back in the drum. That's when I noticed there was no water coming out of the exhaust, nor the pee hole and I shut it off right away. Overheat alarm never sounded, so I thought I'd crank it back up and see what's going on. I let her run for about 30 seconds and never got water to come out. What are the chances that the seafoam had something to do with it? Is it possible that the seafoam broke something loose that is blocking the water passages now?
