Help making bench seats for 17ft Rinker open bow
jort15
I'm building a dog house and a couple bench seats for a 1986 17ft Rinker open bow...my question is would 1/2" plywood be OK to use? Money is pretty tight and I have a ton of 1/2" my question is more about the weight of the wood rather than whether or not to use plywood(particle,OSB) vs. Marine plywood. I figured on using 1/4" or 3/8" until I was given a stack of 1/2 and I'm using the cushions out of a free couch for the cushioning so if I can use the 1/2 and not weigh my boat down to much than the only money I'll have to spend is in the vinyl. Again money is tight and I'm cheap...any help is appreciated...
jort15
Re: Help making bench seats for 17ft Rinker open bow
So it wouldnt be to much weight... mind you that the boat originally had one of those back to back lounge type seats and im replacing that with a bench seat against the side
jort15
as for sealing the plywood my plans are a coat of thompson water seal but ill also be wraping the vinyl around the plywood and stapling but i have some rubber runner mats that i was going to staple to the bottom of the seats
Woodonglass
TWS is CWAP!!! Not worth putting on the wood. Use some Rustoleum Paint and thin the first coat 50% with mineral spirits so it soaks in really well. Then put on 2 more full coats. A full sheet of 1/2 plywood weighs appox. 50 lbs. You'll be fine with the weight.
jbcurt00
Oil based paint, polyurethane, urethane, or varnish would be a significantly better choice then the thompsons.
jort15
Lol first lesson learned...No Thompson! Got it. Will the rubber backing on the bottom help anything or should I skip it and just use the paint or since im pinching pennies here could i cheat on 1 of the 2 finishing coats and use the rubber?
Woodonglass
Rubber, If you've got it would work fine.
jort15
I have some black rubber runner mats like for hallways that are tiled. Its about 1/8" thick.
Woodonglass
That would work fine. Where do you plan on getting your vinyl?
jort15
Dont really have a plan for vinyl yet, i was just looking at prices on ebay compared to my local joAnn fabrics and with shipping it will equal about the same but ebay offers a better variety. Im wanting a simple white and like a smoke grey. Im open to suggestions on where to get the vinyl but it seems im goin to pay around $7/yd either place ive looked. although i saw a 5yd roll of grey on craigslist for $30 so i might try that route too
jimmy wise
Good marine vinyl cost me twice that much up to 40. A yard for some
mbasura
Any prep you do in the paint/waterproofing department is more than what most manufacturers do. Untreated exterior plywood was the standard for about 40 years until the some of the higher end OEMs started using Starboard. Bet most boats still have nothing but exterior ply to form the seat and benches. . .
I second the use of Rustoleum Topside paint from my local hardware store (i think it runs about $12/qt) from my local hardware store (the Depot doesn't carry it). It has been bulletproof so far.
jort15
Any suggestions on the vinyl woodonglass?
Woodonglass
I get all my vinyl from this guy on ebay. He get's end of roll stuff etc. Good prices and good service.
TrimJobber
jort15
That's the guy I was looking at...ships from Florida
