cat toon
Thread starter- Joined
- Sep 20, 2010
- 61
I an running a 70 horse Johnson on the Cat Toon,I took off a 19 pitch prop and put on a 15 pitch prop,I did not run the motor on the toon with the 19 pitch prop because I was thinking that pitch may be to much for the toon,well with the run with the 15 pitch I got 23 miles per hour,showing on my GPS, with 5000 RPM's showing on the Tach,this is wide open trottle,should I drop to 13 pitch to get the extra RPM? Is the 5000 RPM to much strain on the motor? Your knowladge will be appriciated.
