sheboyganjohn
- Joined
- Aug 2, 2005
- 753
I ruled out my last project boat (bad motor) and have found two other ones in the yard, identical boat models but different motors. One boat needs a new transom now, but the rest of the boat is in very good shape, only problem is after market seats that take up too much room. The other boat has a floor that will need to be done soon and a damaged windshield, but oriinal seat in good condition.
So here is where I am stuck. One boat has a 1972 65hp on it. Tested out the shift solinoids and both tested at 6 ohms. LU oil was good. They could not get it to start at the key when they tested it but jumped it to get it to run, and could not shift. Compression is 130 135 130. The other motor is a 1974 70hp. Compression 110 110 120. Both motors need water pumps, they did not circulate and ran hot.
The 72 is on the boat that only needs a transom, so it would be less work then the other boat, but more work on the motor. I also want the motor that is going to be easier to find parts for. I know the lower unit on the 1972 is hard to find parts for, but how about water pumps, power head parts, etc.
And before someone suggests it, no I will not buy both boats and switch motors, even though each one is only $400. I am having a hard enough time convicing the wife we need boat #3, to become the new #2, the old #2 is being parted out this year. #1 is a dedicated duck boat so I don't count it, but she does.
