MolsonCanadian
Thread starter- Joined
- Jul 9, 2010
- 199
I'm attemping to fix some problems the PO made while wiring.
Here is what I HAD:
Hummingbird depthsounder/fishfinder wired so when NAV lights were on, it shut off.
VHF wired in a way that when IGN was on, it turned off (No good)
I removed the old VHF to install a new class D, and in doing so wanted to wire it properly. So I pulled 12v from the blower switch (though now that I think about it, I pulled 12v after the blower fuse) it appears the fuse bank for switches is wired from the ign switch.
NEW VHF and hummingbird are sharing the 12v+ the hummingbird is using the existing ground off one of the gauges. The new VHF is using a ground in another place.
with Both hummingbird and VHF on, and key turned on, VHF turns off while hummingbird remains on.
Do I simply have a ground issue with the VHF? I'd just like to confirm before I yank all the access panels out again.
Thanks!
Here is what I HAD:
Thanks!
