help me find props please..!
bransjeep
i recently repowered my boat with a new 5.7GSi pbyc motor, has DP-A drive with a 1.95 ratio, and B8 aluminum props. boat is 21.5 foot Invader 204 elan v-hull. hit 56 mph on a windless flat day at 4800 rpm...i will be double checkin my tachs accuracy today. i feel there should be more speed, my dad had the boat before me and his motor he put in was way more built up than my new injected motor, it has at least 450 hp, i remember him saying he did somthing with re pitching the props but that setup hit 68 mph regularly..and i want that speed also i will add the boat has a thru-hull stainless marine exhaust system
Thanks,
Brandon
Robbabob
Re: help me find props please..!
Not sure what you're asking. Your dad had a 450 HP engine in it and you put a 250-300(?) HP engine in it. You want the same speed?
http://forums.iboats.com/showthread.php?t=287818
Answer some additional questions from the link and we'll see where we can get.
Art Bernard
Banned
Is 56mph @4800rpm at wot (wide open throttle)? Your engine has an operating rpm range, you want to stay within that range. I dunno what you know about prop pitch and you haven't posted your current prop size so here is an explanation I hope will help you. A prop's size is measured by diameter (first number) and pitch (second number) so a 15 x 15 prop will be 15" in diameter with a 15 deg pitch. with reguards to pitch, the higher the pitch number the more agressive the angle of the blades and the less rpm you will turn but you will get more "power" but less speed. The lower the ptich number the less agressive the angle of the blades and the higher the rpm you will turn. This will give you more top end speed, but sacrifice power and hole shot. Each degree of pitch is worth approx 400-500rpm so lets say your engine has a rpm range of 5000-6500rpm and the prop you have on it now (lets say a 15 x 15) is turning 5500rpm @ wot. If you drop a degree of pitch making your prop a 15 x 14 you should turn around 5000rpm. If you raised your pitch making it a 15 x 17, you should turn aroun 6000rpm. Cup is another way to gain a bit of pitch. Cupping your prop is worth about 250rpm and can be done to fine tune the prop. Lets say you are turning 6000 rpm with a 15 x 17 prop. Adding cup would put you around 6250 rpm. Bear in mind to that your boats hull, the weight of your boat, and how the weight is distributed around the boat will effect rpm. I recomend a stainless prop, you will get better performance out of them and I strongly recomend that you do not exceed the rpm range for your motor, if fact you should leave a bit of cushion. Hope this helps you and good luck.
Art
bransjeep
Art
sorry i left out the fact that it is a Duoprop outdrive, the 450 HP engine went on us because of improperly torqued cam retainer.. im not up to snuff on the whole prop stuff.
this is the third engine this boat has seen, the first was an AQ271c which was i think 260 hp..the went because of freeze damage but with that setup it saw 68 mph as well, which leads me to believe they were changed for the higher hp motor, my current engine is 330 hp, the only numbers on my props are B8 and 0410
