Help me ID my motor.
bob1340
I just got a 7.5 HP Mercury outboard. I am trying to get what model/year I have in order to get parts for it. The serial number tag is damaged but I think I can read enough of it to figure it out.
The numbers I see are as follows
281?525 The center number I cannot see.
Now when I look at this chart I see numbers that are close, but not quite:
http://www.maxrules.com/Merc_model_files/7p5-9p9.html
I am guessing it is a 1969 or1970 motor??
It also says:
"Kiekhaefer" on the front of the Aluminum/Metal cover and has "Thunderbolt Ignition" on it.
It has good compression. I squirted a tad of gas mix in the carb and she started right up. I intend to put a new water pump in it and basically clean it up and check the oil.
What do I have here? I have never owned a Merc. Bob
Dunaruna
Re: Help me ID my motor.
Yes, 1969 or 1970. The middle number will determine which year.
Doesn't matter anyway, the pumps are the same for either year. Part # 46-46893A6
bob1340
Thank You. Looks like parts are scarcer and more expensive for these Mercury motors than Evinrudes.
