Bam_Bam_of_Atlanta
Thread starter- Joined
- Oct 27, 2010
- 19
It measures 14' long, 64 3/4" beam, HIN 45217, 925lb rating, 40hp max
My best estimate so far for 14, 64 3/4" Beam Models w/40hp: 1959 SportsmanCust. 275lbs, 1959 Sportsman Del. 250lbs, 1960 Sportsman Cust. 365lbs,
For those interested:
I bought the boat with a perfect running 1964 Evinrude 40HP Big Twin. I have a 12", 13 1/4" and 14" pitch aluminum props and one 14" bronze that looks PERFECT
The boat is so light and the motor 100% rev limited that speed seems to be strictly controlled by prop pitch.
So far I have only used the under pitched 12. The 13 ? spun about 300 into the first ride. I have a new hub for it.
These Evinrude Big Twins have no over rev capabilities. Since I got the 14 aluminum prop so cheap and the bronze is much better, I plan to try to re-pitch it and add some cup. It will be a DIY I have nothing to lose experiment. Lol The internet has some great guidelines to help on the science side of the science/art of props.
She seems to cruise at about 2 gallons an hour. The 12 gallon tank seems to run all day with 1/2 left over.
I scheduled buying a 6 gallon tank this weekend. That will save weight on the tank and fuel. The motor was also shimmed about 3/4" up and about 5 degrees more trim since she was on the last trim hole. Still have to test.
I hope with the thinner bronze prop with more pitch, less weight, and the motor raised a tad, that she will burn a bit less fuel and I have little doubt top speed will improve. If the water is smooth, GPS will let me know.
I have repainted the hull & motor w/new decals. Polished out the Nautalloy steering wheel. Rebuilt the Transom. Welded up over 20 holes and about 20 cracks! Seems every boat I buy was Swiss cheesed by the previous owner(s). New classic seats are ready to mount. All the bolts to the ski rope anchors snapped so they had to be drilled, tapped and studs put in. Lucky, Holley carburetor studs worked perfect.
I am trying to finish up the wiring to get it back on the water since rebuilding the transom.
Still have to add the Humminbird 587ci HD, 12v & 5.5v USB outlets. I just found out these motors have no charging systems.
It came with a new big deep cycle battery anyway.
The wiring harness for the KIA Soul EV came in. This will be a good test on an EV pulling a boat. Im guessing it will take a 30 - 50% hit on range.
The Town Car could not even feel it back there. They are light.
The two tone paint job helps give it a classic wagon look. That should help match a modern car w/a classic boat.
I have charted every item & its weight to keep it as light as possible. That includes the trailer, now w/LEDs
This is my first flat bottomed transom boat. My god she rides rough in rough water. I have not been beaten like that (Allatoona Lake Memorial weekend) since riding 70s Motor-Cross bikes! I did notice she landed much softer nose first using the V bow than landing on the back end. The internet said to trim the front down so that the V bow is hitting first and accept you will lose speed. Now you know why the transom was rebuilt several years before planned. Allatoona Lake looks more like the ocean on Memorial weekend and it was fun playing Burt Reynolds in Gator. Lol! It is so light and small that you cant help but stand up and run it like a JetSki.
The draft is ridicules with the motor raised. She only needed 3-4 of water to float over sand bars on the Chattahoochee river. This is where I will only use the most beat up prop I have. It will come back a little more beat up, but what a beautiful place to cruise.
It gets compliments everywhere I go! Strange since it looked like #&&^$ when first bought it. The picture does not give you a clue how ragged out it was. I would hate to see what they called ugly.
My biggest challenge seems to be the crazed 11.3lbs windshield. Told you I was weighing every part to get her light. Internet says you can sand it out and polish it. Ummm I am having my doubts.
I will try to take some pictures this weekend. In a few weeks I will know more on its speed potential.
