Ki Ki
Thread starter- Joined
- Jul 12, 2010
- 292
the wire you see is not for the transducer..its for a speedometer....it is tilted up it should be down to get a reading..its just a hollow tube....I believe its called a pilot....
Oh, I figured my speedometer was just broken. So I can presumably flip that down and it will go to the speedometer?
I think it's actually "pitot", and good catch on it being flipped! Seems a good design that it moves out of the water if it comes in contact with something more dense that water.
Oh, and I have another suggestion... You could fabricate another similarly shaped bracket, either a little wider or narrower, that fits over the current bracket (and is attached from the sides). This would present a flat surface to mount a new FF to.
