jonny rotten
Thread starter- Joined
- Jan 8, 2012
- 380
I'm having trouble wrapping my head around this.I have a mercruiser engine.The steering is stuck.After much research I unscrewed the large nut before the tube.The steering turned with ease.The bar slide in and out of the tube with ease.The other side of the tube with the 3/4 "stainless tube coming out is frozen solid.How can one side slide in and out while the other side is frozen?? How do they connect inside the tube?? The manual says to lube the 3/4 stainless tube so I assume it moves.I read to torch the tube so I did while a buddy tried to move the outdrive with no luck.(the large screw still unscrewed).Could someone try to explain how the cable works inside the tube so I can get this unstuck..Thanks
