scanman
- Joined
- Jul 29, 2010
- 370
I have a 1975 evinrude 9.9. After a complete overhaul, a 15hp carb, & Boysen double reeds, it makes around 18hp. It's mounted on my 13'6" alum. Jon. With me, the 12gal fuel tank, & the troller & batt, I'm gettin 21.9 mph on the gps. I've heard I should be gettin more, though. I've done moderate research, on this forum, & it seems I'm gettin more confused. Is there an easy way to understand the relationships between mounting height, tilt, trim, & prop sixe & pitch. I'm quite sure all these things are affected by each other, but how? BTW, I'm still runnin the OEM alum prop for the 9.9hp Evinrude & it's mounted al the way down on the transom as low as it'll go. The trim pin is in thesecond hole up from the transom, making the motor nearly 90 degrees to the surface when it's in the water. When it's on a plane, it does feel like it's plowin ever so slightly. It seems to have a bow down attitude, & never really gets to "skippin" over the water.
