mikey'smoneypit
Thread starter- Joined
- Jun 22, 2010
- 1
hi, i just boat a 18.5 ft wahoo with a 1996 115 Johnson ocean runner. the boat ran great when we took it on its water test. how ever when i took it out today it was running fine under 3,000 rpm's. as soon as we took it over 4,500 rpm's the steady motor alarm went off. i immediately backed the motor down to idle. the alarm stopped going off after 30 seconds. we idled it back to the dock. after doing research on hear it seems like it could be the temp or fuel restriction alarm. heres where i need help fast. i dropped the boat off at a mechanic and he ran a compression check and 3 cylinders are at 130 and the 4th at 95. i know its low. he immediately said the motor needs a complete rebuild. i asked did you find out why the alarm went off and he said he will find out more once he tears the motor down. i don't have the money for a complete rebuild. that still did not answer my question on why the alarm went off. it could be as simple as a fuel related issue.
even though the compression is low on the 4th cylinder this motor starts right up. idles and runs like a brand new motor as long as your under 4,000 rpm's. what should i do??? how long could this motor run with the compression being low on cylinder 4??? i just boat this for the summer for me and my two boys and don't really want to pay 2,000 or more for a rebuild, but i don't want to blow the motor up. sorry for the long post. please help.
thanks,mike
thanks,mike
