Originally Posted by mocha0403
115 johnson, i have to put throtle all the way full and hold the choke at the same time before it will start in the water. but on the hose, no choke and no throtle and it starts up great. what could it be thanks
It takes considerably more starter power to reach the necessary RPM to fire the ignition when there is a load from being in the water. This is especially true if the motor is set low in the water as in starting while the boat is still partly loaded on a trailer.
