EvinrudeBill
Thread starter- Joined
- Sep 4, 2009
- 1
I'm stumped and need some help here guys..... over 30 days and counting.
On the hose(muffs) it starts and runs great all day.... but idles very high (2400 rpm). When in the water it starts very hard, idles very poorly at best, and does not take acceleration very well. Boogs down and quits 50% of the time. (reverse is the worst) Quits evertime. Seems as if the motor loads up. On mid and top end, if you can get it there, it runs out perfect all day. Basically it's not happy with back pressure..... and idles high out of water. Also, the motor does not sound right..... its sounds raspy out of water and muffiled and restricted in the water.
O.K. here's what I've done so far. Complete carb. rebuilds with OMC carb. kits and cleaning. I found nothing. Next, I checked all hose and connections. Again nothing. Did the link and sync according to the service manuel and checked the timing. All good to go. Next, I found another 87 120 that runs good. Compared linkage and timing between both motors and found everything is up to par with my motor. Compression tested 124-126 psi on all 4 cylinders. For a goof, I pulled the heads. Cylinders look great and exhaust ports are clean as a whistle. Again nothing out of wak here. Installed new head gaskets, thermostats and thremostat diaphrams. Next, I pulled the intake manifold off to check out the reeds. Yup... you guessed it looks like it came off the assembly line. The VRO pump was replaced two yrs. ago... so I can't hardly believe my problem lies here. I have fresh gas in the tank and am using Merc QuicSilver TCW-3 oil.
Not that it matters but this motor has very low hours and it has never seen salt.. fresh water only.
I'm thinking bad crank seal next..????? What do you guys think??
Any help here would be greatly appreciated! : )
Thanks!!!! Bill
Thanks!!!! Bill
