HELP! Need Distributor cap for 76 115 I6
shirthero
I Might be able to salvage the one i have but its not looking good, and everywhere I turn I find it is no longer available! Help please, where can a guy find one and maybe even a rotor while I'm at it
shirthero
Re: HELP! Need Distributor cap for 76 115 I6
ok, Cap will live, but all the wires fell apart when I took the cap off, can i run push in style wires, or do i have to find somehow the screw in wires? also, the coil wire is not coming out of the coil, is it also a screw type, cause I have spun it and spun it, and have tugged on it but don't want to mess up the coil, however the distributor end of the coil wires fell off with the rest, any help guys?
Shirt, The coil wire screws into the dissy cap and pushes into the coil tower. The plug wires screw into the dissy cap and are available for less that $10 each at vintageoutboards.com You want the 36" tigertails
shirthero
So go ahead and pull it out of the coil, just didnt want to screw up another hard to find item, and I'm guessing I shouldnt try to find a set of automotive wires to swap in there huh?
