Help, need to ID my bearing carrier, lower unit was replaced and unknown year or make
emegolf
I have a omc 1990 5.8. lower unit was replaced and I cannot fine any parts manual with a 1/4 screw/nut holding a anti rotation pin on the bearing carrier. My lower unit will not hold a vacuum unless grease is applied around the prop shaft. I need to remove the bearing carrier, but there is a part that I do not know how to remove. any help is apreciated. Attached is the photo and on the 9 o'clock position is a key that needs to be removed (the holding screw was removed)prop sht.jpg
jerryjerry05
Re: Help, need to ID my bearing carrier, lower unit was replaced and unknown year or
That should just knock out if the screw is removed.
Deep inside there might be 4 bolts holding the carrier in.
This is a lower from 1990 5.7 The pics attached.
http://www. boats. net /parts/search/OMC/SternDrive/parts.html
Remove the spaces.
emegolf
Remove the spaces.
Thanks for the help. I got the bearing carrier out.
