help needed power trim wiring route Mercury 70Hp 1989 3 cylinder - photo needed
appleo
Prior owner cut the power trim wires at the motor (blue, green , black). I have soldered 3 foot extensions to each and shrink tubed together
I need to determine the route to get them up under the cowl and to the soldenoids
Does anyone have a actual photo they could share showing the route of the power trim wires ?
Thanks appleo
CadoTx
My 87 Mercury trim wires go into the cowling where the fuel line and battery wires are routed.
Texasmark
Since now a days most remotes have PTT in the shift/throttle handle, the wiring comes from the control with the other wires needed to operate your engine ......start, prime, 12v for acc. and ignition switch, ground. If you have Ptt in the control, peel the plastic cover back on the wiring harness at the engine and you may find your cut off wires. Otherwise right where Cado Tx said because that's where they are when they are where they are where they are supposed to be???????? did that come out right?
appleo
Not quite
I am seeking photo of wires path from trim motor to the 2 relays under the cowl
