jimmy spy.
Thread starter- Joined
- Jan 9, 2011
- 23
Hello! First time posting here, so I apologize if this is in the wrong section. I also apologize for the wordy first post.
I've got a 1985 Johnson 70HP VRO outboard that I recently transplanted onto a 1965 Starcraft Del-Ray. Up until a month or so ago, the motor had been sitting for close to 10 years. Because of this, I took it to a mechanic to have the carbs rebuilt and have the water pump replaced ( I generally would attempt a repair like this myself, but I got a good deal on the boat and didn't really want to mess with the carbs). Well, I got a call from the mechanic saying that they couldn't get the motor to run right, and they were sure it wasn't a carb issue. I did't want to pay their hourly rate to have them look into the issue farther, so I picked the boat up this past weekend and plan to fix it my self.
So, here is what the motor is doing. It starts up and idles fine (although the idle is set way too high), and will go into gear, but it bogs down and dies when you try to give it anymore than 1/4 throttle or so. After playing with it for awhile, I could get the motor to open up by dropping it in gear and immediately going to WOT (this only seems to work some of the time). Once you get the motor to open up, it runs beautifully. You can adjust the throttle freely without it bogging down or stalling until you get back down to 1/3 to 1/4 throttle or so, then you have to play the "floor it and hope it doesn't stall" game again. When backing the motor down from WOT, it doesn't bog down or stall out at any point in the rpm range; issue only seems to occur under acceleration. Issue also seems to be independent of motor temp (does it from a cold start and at operating temp).
The motor has good compression and spark seems to be fine. As mentioned, all 3 carbs have been rebuilt. The motor does have the VRO fuel pump still, but the oil injection line is blocked off.
So, any ideas on what could be causing this issue?
