Help needed with baron sportsman
Baron Custom
Hi I'm a new member, my name is Darryl and I live in Australia...
A mate and I bought a 19 foot Baron it is an Aussie boat from the early 80s, It was a stern drive but has had a pod fitted to it, I noticed there was water under the fuel tank storage area so I cut out the floor of this spot and found a stringer set up that has NO drainage at all.. This spot is in pic's, The floor is good and not soft anywhere but I am thinking about re-doing it as most of the floor will be changed to use old engine compartment as catch tank:eek:,The boat only has tiny little bulkhead's that I would like to make some new "real" one's, The floor in the V berth has a crack in it and no drainage [ i bet ].. having problems putting up pic it's asking for url number whats that? can some one tell me how to do it .. Cheers Darryl :D
Baron Custom
Re: Help needed with baron sportsman
Also i bought some divinacell [ prob not correct spelling :confused:] was going to use it to make lid's for in floor tank's only to be told if i use polly on it it will dissolve now i have the issue of having to use both, polly and epoxy.. Is this the ''done thing'' If not then how ? Thanks for any help you can give ! Cheer's Darryl.....:D Still cant sort pic out so you can see work done so far and problem spot.................:mad:
