Help needed with Volvo Penta Easy Connect Gateway selection
hawkeyestoob
I think I am going to try to buy the Volvo Penta Easy Connect Gateway for my engine to see if I can see the actual error code causing the alarm I am getting around 3000RPM and up once it is up to operation temp. I have replaced the impeller and both manifold sensors as well as confirming that it is not running hot with a IR thermometer.
The problem I am having is that it is not completely clear which model gateway I need. I have been told both 23870792 and 23870794 from Volvo dealers but neither seem overly certain. My engine is in my 2015 Regal 2500. The engine is model V8-380-C-D, serial # A289486.
Any help would be greatly appreciated.
dingbat
SKU:23870794
interface kit is intended for Interface kit for, non-EVC gasoline engines 2007 and later
SKU:23870792-seems to be special order
hawkeyestoob
I ended up not needing the Easy Connect. The issue I was having was caused by seawater pump that had some strange wear in it from something that happened with the previous owner. I replaced it this week and the alarm has gone away and the boat runs great.
