Re: Help, No fire on '73 Evinrude 50hp
Hi I found these 2 under <br />Topic: 1971 60hp johnson with hydro electric drive <br /><br />From this it may be reasonable to guess that the unit may only go into neutral when the key is on.<br /><br />I have seen a link in one of the Evinrude topics for a place that will supply manuals. Sorry I cannot find it right now<br /><br />These might help you.<br /><br />This came from Joe Reves<br /><br />(Battery Capacitance Dischage Powerpack Test)<br /><br />Purchase a small 12v bulb at your local automotive parts store, Radio Shack, Wherever, (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. <br /><br />Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (usually a purple wire). Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire). <br /><br />Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed. <br /><br />Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.<br /><br />From Schematic<br /><br />should be 2 wires going down into leg. Blue and green.<br /><br />no voltage to either = forward<br />voltage to green and blue = reverse<br />voltage to green only = neutral<br /><br />check these voltages. If you have them as specified, flush the bottom gear oil with dextron III and refill with the proper oil "type C"<br /><br />if you don't have power to the green only when in neutral, check the switch in control box....<br /><br />disconnect the green and blue solenoid wires at the knife connectors. Check the resistance of each solenoid by going from green to ground, then blue to ground. You should get 5-6ohms on each lead. A shorted (less resistance) solenoid will cause high diode temp.....
