alien4fish
- Joined
- Apr 1, 2010
- 80
Hi forum,
Here is my delima, i just purchased a 1981 sea ray with a Mercruiser 260 and merc alpha1 out drive. I checked out the boat at the guys house and it started right up and ran well in the driveway, the engine reved well, no knocks no pings. The tilt drive had a leak in the clear line that runs to the lockout, I replaced the line and then took the boat down to the water to sea trial the boat to see how it would do in the harbor, when i was at idle in gear cruising around the harbor it was running well, when I went to power it up in started to run very rough under load. I could only get it up to 2000 rpm's and it would miss and run very rough. I figured it may need a carb cleaning or replacement( no big deal i could do that) there was a small amount of smoke that was coming from what looked to be the heads however, when we came in to the dock, there was a ticking noise coming from the engine compartment when we opened the hatch there was oil in the bilge, doing a brief inspection at the dock it looks like oil is coming from the back of the heads. The engine temp was running a little on the high side(impeller?) I can fix that. So I called the guy that sold me the boat, and expressed my displeasure and let him know I will be returning the boat in the event that the motor is toast, we never even got the boat out of the harbor, the problems started almost right away. how can it run really well while in the yard but run so poorly under load? I can take some pix and post them if needed. Am I screwed and need to replace the motor?
is this something I can fix myself?
My apologies if My Grammar isnt perfect right now im just a little pissed off at the moment.
Thanks for any help in advance.
Kevin
Kevin
