help, no rpms
mh11
Hello it's me again 1978 galaxie 22 xl merc 260
Got it on the water today, runs worse than before last year.
Used to turn 3900-4000 rpm
Today 3000 rpm, and it backfires worse at WOT.
Replaced fuel filter at carb, and the water seperating unit as well.
Help!!!! Should I blow out the anti siphon valve on each tank?
Don S
Re: help, no rpms
List of possible causes of low WOT (Wide Open Throttle) rpm.
In no particular order
Engine Won't Reach Operating RPM. Check
1. Fuel condition. Type and Octane possibly old fuel
2. Propeller pitch or diameter, damaged blades
3. Restricted fuel pickup tube or anti siphon valve Fuel System Test
4. Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
5. Marine growth on hull and outdrive
6. Wrong gear ratio in outdrive
7. Restricted carburetor air intake (clogged flame arrestor)
8. Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
9. Poor cylinder compression Compression Test
10. Carburetor defective, or wrong type.
11. Fuel pump pressure and vacuum
12. Boat overloaded, improperly loaded, or improperly trimmed.
13. Engine Overheating
14. Engine timing and ignition system operation
15. Remote control cables and linkage for proper travel to open throttle plates fully.
Re: help, no rpms
Ayuh,... Probably Trash in the Carb,.... Rebuild, or replace it...
mh11
Re: help, no rpms
Brand new fuel
prop 3 runs on it 17p
Oil is correct level
Hull and outdrive are clean
Gear ratio is correct
This is where I think I may have a problem, the engine compartment is closed off except for the vents that go to blower, should I cut hole in top of engine cover and put scoop on?
Should I pull risers off and check this
Seems as if this might be problem, should I buy new rebuilt one?
Can local boat shop check this for me?
Trim is correct, boat not overloaded
Boat runs 135 to 140F steady, not overheating at all
Local shop set timing and evrything for me. Should be good.
Checked these, looks like they open all the way.
Let me know what you think please Don, thanks!
gdombroski
Re: help, no rpms
You didn't have an answer to this one. Blowing it out will probably not do any good. Just replace it about $15.
