HELP-Nut on top of fuel tank outlets needed???
rost495
Don't know if this is the right place, I don't know what to ask for or where to look. Getting my rig closer to water testing. Used 85 Hydrasport 21 CC. It has a poly 80 gallon tank(what I was told anyway)
There are 3 fittings on top of the tank. 1 Vent, 2 sources of fuel feed.(and of course the fill neck....) All 3 are aluminun fittings. Just realized today that one had a nut missing that holds the fitting from falling down into the tank. Then tried to take another one off to see about getting a new one and it was cracked already so I may as well buy 3 new ones.
Its a thin flat looking aluminum nut. Its about 1/4 inch thick, ID is appx 3/4 inch and looks to be fine threads basically.
HELP??
Thanks, Jeff
Coors
Re: HELP-Nut on top of fuel tank outlets needed???
Take the cracked pieces and match them up.
rost495
Size isn't the issue, its finding a source! Thanks for the words, now I know what to look for bulkhead fittings. Just a matter of locating a source of them now that I know what it is called.
Jeff
