Have never seen or dealt with sea drives before.. everything I've heard about them is very negative though.<br /><br />I found a boat I really love, thing happens to have two '89 140 HP OMC sea drives. One of them has a slightly scored cylinder.<br /><br />Was under the impression that the sea drives were regular envinrude V4 140's on a funny bracket.. figured I'd just build the powerhead, using the readily available parts I can get for the V4 140 ouboards. <br /><br />Was just informed, and it seems by some searching, that the powerheads between these two engines are not identical.<br /><br />Is this true? What is different, and is there an avenue for parts for these engines? Could someone please set me straight on this - I don't even know where to find sea drive info.<br /><br />Buying the boat cheap or not at all either way, but was figuring I could at least run the engines installed on it for a while and later repower if I hated the sea drives. If they are not fixable it makes a huge difference. If parts availability aside from the bracket assembly is in question, will have to consider the boat in a much differnt light.<br /><br />Thanks in advance.<br /><br />Jon
