Well slight update fellas...I shot some starting fluid into the carbs, hit the key and it fired right up! So, I guess its pretty obvious I have a fuel delivery problem...that at least narrows it down...how would be the best way to make sure the fuel pumps are pumping out the right amount without just rebuilding them? I pulled the outlet line off and there is fuel shooting out, but ive seen that on a car where thats the case, but its not enough volume under pressure??
